VGA to VGA??
Discussion in 'Microsoft Windows' started by Longhorn, Mar 14, 2006.
  1. Longhorn
    Longhorn
    Excuse my lack of knowledge but alot of post here on coming out of Gfx card with vga then making a custom cable to take u to scart etc.
    If i have a vga port on my plasma can i come out of gfx card and go VGA all the way and what picture quality should i expect compared to scart eg????
    Thanks in advance
    LH
  2. rEVILospud
    rEVILospud
    May 1, 2005
    2,295
    Shoreham-by-Sea
    +235
    Go VGA all the way!
    VGA is far superior than scart; the only reason you would ever go the scart route is if your TV didn't have a VGA or DVI input.
    VGA supports all the PC resolutions available on your graphics card (this includes High Definition); Scart is only standard definition and the picture will be poor quality.
  3. deksawyer
    deksawyer
    May 26, 2005
    1,641
    Fife, Scotland
    +132
    Correct on the first point, but completely wrong on the second!:cool:
    D.
  4. Longhorn
    Longhorn
    Many thanks for the speedy replies, i have embedded a 10m scart cable in my wall but if i snip off the scart connectors and solder some VGA connectors on would this work okay??
    Thanks again
    LH
  5. stevelup
    stevelup
    Aug 13, 2002
    6,795
    Swindon
    +1,298
    As long as the cable you buried has at least three proper coaxial cables in there (preferably five), you should be OK.
    By the way, 15-Dsubs are an absolute b*tch to solder - truly awful. I'd recommend fitting BNC's to each end of your embedded cable, then buy a couple of VGA > BNC cables from any computer shop.
    Steve
  6. Longhorn
    Longhorn
    Cheers steve! Will attempt the VGA Soldering route.
