VGA to TV converters
Discussion in 'Desktop & Laptop Computers Forum' started by mjvdvlugt, Aug 31, 2004.
  1. mjvdvlugt
    mjvdvlugt
    Is there a quality difference between a video-card TV-Out and those PC->TV converters?
    My pc has an on-board video-card (and: no AGP slot) but I do need a tv-out to build my HTPC!
    Does anyone have experience with those VGA to TV converters? And do they give good output when playing the interlaced video's my tv-card produces?
  2. cowtipper
    cowtipper
    Jan 29, 2004
    164
    19
    i have had a few of these boxes ranging from corded to cordless and i have not been very happy with them the cordless one was the best but you can see a slight flicker which annoyed the crap out of me if you could have got rid of this they would been semi acceptable
  3. mjvdvlugt
    mjvdvlugt
    Ok. That's good.. Did you have good video playback? Like DVD?
  4. cowtipper
    cowtipper
    Jan 29, 2004
    164
    19
    it made the MPeg artifacts more apparent and like i said the flickering was not good
  5. mjvdvlugt
    mjvdvlugt
    Thanx for the info! I'm gonna buy one!
  6. uczmeg
    uczmeg
    May 18, 2003
    3,150
    71
    Nottingham
    +45
    Am I reading the same thread here? Everything Cowtipper has said suggests buying one is a bad idea doesn't it?
    Marc
  7. mjvdvlugt
    mjvdvlugt
    Well. I meant it like: "Thanks for the info!"
    The backgroundstory is that I heard somewhere animated output would become a mess, and that those converters were only good for static things (presentations etc.).
    But now I know that's not true, and it could be acceptible I'm going to the shop with my laptop to try it out. So by "buying one" i meant: go to the shop and hope to buy one.
    If anyone has some more experience to tell me beforehand I really would like to know.
    Thanx!
  8. uczmeg
    uczmeg
    May 18, 2003
    3,150
    71
    Nottingham
    +45
    I assume we are talking about CRT TVs not LCD/Plasma TVs?
    If this is the case then the best TV output I have got is by using a Realmagic Xcard.
    The limitation of this is that it only outputs video and not a PC Desktop.
    However you can use it with Joveplayer, now called TVedia or something like that and you get a whole media centre interface for video, music the web etc. A really impressive piece of software that works great with the Xcard and a TV. (The Xcard coms with a remote). Go to www.8dim.com to find out more.
    Marc
  9. alfaman
    alfaman
    If you've got an RGB SCART and can solder ......
    http://www.idiots.org.uk/vga_rgb_scart/index.html
    Try a DIY solution - do be careful about setting your refresh rates I'd look at creating a monitor definition file set up to prevent you doing something you might regret (limit resolutions and refresh rates. Have a look at powerstrip.
    Simon
