VGA to SCART wow!!
Discussion in 'Desktop & Laptop Computers Forum' started by Spacecat, Aug 23, 2005.
  1. Spacecat
    Spacecat
    Apr 1, 2001
    3,350
    London
    +984
    Just installed the Keene VGA tor Scart cable bought from someone here for £25 .
    All i can say is WOW!!, the picture quality is superb and unlike using the VGA connection the aspect ratio is also perfect.
    indistinguishable form the direct feed
    Im yet to see a LCD or Plasma that matches CRT in my eyes at least for anything like reasonable money so this is a godsend.
    If you have widescreen CRT TV with a RGB Scart and use MCE with RGB GET ONE!!!
  2. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    Did you use power strip to set the reolution, and if so what res did you select, also what would you recomend for a 4X3 TV...
  3. SteveL
    SteveL
    May 19, 2005
    81
    Bristol, UK
    +7
    Got to agree with the OP here, I just recently made one of these cables and the picture quality really is amazing :thumbsup:
    My cable is 15metres long and I was worried about signal loss/crosstalk, but haven't got any of either. This is a WORLD away from the quality of S-Video.
    meansizzler..I use PowerStrip to set a custom resolution of 960x540@50Hz, for a PAL Widescreen TV, the following thread has all the info you need, including some timings for 4:3 TVs.
    http://www.avforums.com/forums/showthread.php?t=136811&page=1&pp=15
    This cable will ONLY work on Radeon cards
  4. Spacecat
    Spacecat
    Apr 1, 2001
    3,350
    London
    +984
    im using 16:9 mode 1024x576 resolution
    PowerStrip timing parameters:
    1024x576=1024,32,96,112,576,5,5,39,19750,312
    this is on a Loewe Aconda 32 widescreen Tv
