VGA to Scart issues
Discussion in 'Desktop & Laptop Computers Forum' started by DaveP, Jun 15, 2005.
  1. DaveP
    DaveP
    I already posted in the main thread that I initially had problems, and then reported that all was well and working. The problem is, there is more to it than that!
    I couldn't get it working on my intended PC (Celeron 1.7Ghz) but I did get it working on an old P3 1Ghz machine. This was using the same ATI 9200SE graphics card.
    I have now spent the past week trying to get it working in the Celeron based machine but I'm getting nowhere. :confused: All I get is the small rectangular blocks al over the screen (I've tried turning off tiling)
    I just had this thought that maybe it's down to the Celeron (being cut back the way it is, and not a "real" pentium).
    Is this possible? Is anyone using this cable on a Celeron based PC?
    Dave
  2. MikeTV
    MikeTV
    Feb 1, 2003
    7,782
    Ealing, London
    +842
    I don't think the CPU will make any difference at all.
    My best guess is that perhaps it is the radeon driver versions you are using? For a while, some earlier versions of the drivers wouldn't support interlaced resolutions.
    I assume everything else is the same? ie. the o/s, powerstrip, etc. Perhaps you need to make/change the monitor driver?
