VGA to SCART AND ty-st42pa20 stand
Discussion in 'Plasma TVs Forum' started by leighv, Apr 20, 2005.
  1. leighv
    leighv
    Apr 6, 2003
    47
    I wondered whether anybody could help....
    I have a Panasonic TH42PE30 and Panasonic have thoughtfully put the VGA socket on the front of the screen and it also means that when it is connected you can't actually close the panel where the hphone socket, volume controls etc, live. That's quite a problem as I don't want the VGA lead from my PC hanging down and the panel open. So my question is can I somehow get a VGA to SCART lead or is there another suggestion??
    Also I have bought a ty-st42pa20 stand. I have tried to attach the tv to the stand. In the instruction manual it says on page 4 - point 3 - Fasten with screws - securely fasten using long screws. I have tried to do this - but the picture does not seem to apply to my television. Can you help? Rgds.
  2. Light_User
    Light_User
    Feb 10, 2005
    305
    +6
    Re: your cable problem - try asking someone on the forum - other av subjects, or the computer forum. Also, try a search on the Forum's home page. I have found a thread from last June which may or may not help. http://www.avforums.com/forums/showthread.php?t=136811&highlight=vga+scart
    Bad news on your stand though - you have bought the wrong one. You need to get the TYST42PX20.
    Good luck.
  3. leighv
    leighv
    Apr 6, 2003
    47
    Hi - thanks for your reply.... However this is what I was told by a supplier.....
    The PX20 is the purpose built model for the 37" & 42" Viera range and are squarer in shape.
    The PA20 was designed for the older model Plasma TV but has the same fitting pegs. It's appearance is different though - more eliptical, and has been used as an alternative option to the PX20 as they are hard to get hold of, seperate to the screen itself.
  4. Light_User
    Light_User
    Feb 10, 2005
    305
    +6
    Maybe you need to go back to the supplier - if they have a screen and stand in stock then they can try to fit them together and tell you how to do it !! :D
    Then if it is not possible, ask them to send you the correct stand or a refund. Try this site - also a few others - I have not searched for the cheapest - just to prove that there are retailers who sell the stand.
    http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/1943
