VGA to DVI
Discussion in 'Desktop & Laptop Computers Forum' started by Stellavision, Apr 16, 2005.
  1. Stellavision
    Stellavision
    Apr 7, 2003
    2,379
    Southsea, UK
    +101
    Would using a VGA to DVI cable like one seen HERE give good results for HD output via my HTPC?
    At the moment I need a solution for getting a HD signal from the VGA output on my Radeon X850 XT into the DVI input on my Hitachi plasma. I can still get good resolutions, but it is technically still analogue.
    Due to room lay out and cabling, it isn't practical to simply run a dvi to dvi from the pc at the moment and a vga cable already runs under the floor.
    It may just save may from having to build a brand new HTPC in the same room as my hi spek desktop.
  2. Stellavision
    Stellavision
    Apr 7, 2003
    2,379
    Southsea, UK
    +101
    Forget that. I've just realized that it only enables a DVI-A connection.
    Back to the drawing board. :mad:
