VGA svp-310 help
Discussion in 'Projectors, Screens & Video Processors' started by NikSoftware, Sep 22, 2004.
  1. NikSoftware
    NikSoftware
    Aug 20, 2004
    20
    Reading
    What is the native resolution of the 310?
    what are the frequency limits of the 310 on rgbhv bnc's?
    and/or the needed front and back porch settings?
    and sync width?
    the best i get when i try various resolutions are is two copies of the picture displayed side by side, but it is unstable and sometimes loses sync altogether
    so i imagine im pushing the limits on the freq?
    ive tried 640/480-720/576-800/600-1024/768 with no luck. :rolleyes:
  2. Rob
    Rob
    Jul 17, 2000
    1,285
    Norwich
    +33
    The SVP-310 is a video-only unit i.e it is limited to 480i,576i (interlaced) inputs. It cannot display a progressive feed. Horizontal scan frequency is limited to 15.6Khz.
    Hope this helps.
  3. NikSoftware
    NikSoftware
    Aug 20, 2004
    20
    Reading
    ok in this case why is there 5bnc connection?
    rgbhv?
  4. AndyFov
    AndyFov
    Nov 20, 2002
    1,472
    March, Cambs
    +45
    As you say just for RGB with sync, but only at mc regular scanrates,
    The 310 was a good pub projector really, it's suitable for using a Sky box or a tuner in a video for a big screen image. It's not data grade, so you'll not be able to utilise a HCPC or line doubler.
    Andy
