VGA stretch on 42 Samsung Q97
Discussion in 'Samsung TVs Forum' started by Aram, Sep 11, 2007.
  1. Aram
    Aram
    Hi guys
    I have just set up my HTPC connecting it to a samsung 42" Q97 via VGA port. However I cant seem to set the output resolution of the PC to WXGA, only XGA meaning that the image gets stretched to fill the screen.
    I know that 42" plasmas have an XGA resolution, but on my parents Panasonic PX70, I can set the out put to 1336x768 and the TV displays it correctly, and I dont understand why my pc/tv wont let me do that.
    I have tried it using the intergrated GeForce 6150 (same as my parents) and also a seperate GF 7100, but both only give me 3 resolution options: 800x600, 9xx x 6xx and 1024x768. Im using the latest forceware R162 drivers.
    This makes me think its the TV that can only accept these resolutions, but Ive tried DVI to HDMI and I still only get the same res options, and there is also an overscan issue on the HDMI.
    Anyone have any ideas?
    Aram
  2. s_inman
    s_inman
    Mar 16, 2006
    2,512
    Kendal, Cumbria
    +308
    Have you tried powerstrip? It has the ability to do custom resolutions etc.
  3. Aram
    Aram
    I havn't, Ill give it a try tonight
    Thanx mate :thumbsup:
  4. Aram
    Aram
    nope, unfortunately that doesnt work, it seems the Screen will just not accept a widescreen resolution, which seems rediculous but I gues thats just the way it is.
    Thanks for the reply tho, and if anyone else has any ideas they would be much appreciated:)
    Aram
