VGA splitter - Three inputs to Two outputs?
Discussion in 'Cables & Switches' started by Dancharles08, Mar 2, 2013.
  1. Dancharles08
    Dancharles08
    Jul 8, 2012
    26
    3
    Hello
    I currently own a projector and TV with VGA input
    What I'd like to do is have a switcher box with three inputs ((Xbox, Mac mini (2006) and Sky) I already own HDMI - VGA converters for Xbox and Sky, and a DVI to VGA converter for the Mac) and be able to choose between these on two displays without having to change cables manually.
    Has anyone got any ideas/ input/ experience of something similar?
    Many thanks
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,633
    The Borders
    +3,504
    You require a VGA Matrix if you wish to be able to view different sources simultaneously on your two display devices.
    Kramer would be our first choice when supplying a budget solution – though still relatively expensive if you are hoping for a very low cost solution.
    VP-4x4K - Fixed I/O - Kramer Electronics
    If you can limit the system to choosing one Source to be mirrored on both Displays a less costly 3x2 Switch/Distribution Amp would fit the bill.
    VP-32K - Single Output - Kramer Electronics
    Joe
