VGA spilter display problem
needtoknow
I got one LCD monitor
and I have one PC and one Xbox
I have brought a VGA spitler so I can share the two with one monitor.
everything works fine
apart from the PC where the images r blurrly and you would get this shadow effect when you look at the images. the xbox is fine.
please help ?
how do I get back to the original effect
EndlessWaves
If you switch the ports the PC and Xbox are plugged into does the problem disappear or appear when using the xbox instead?
Is the PC set to run the LCD at it's native resolution?
DJACID
first check the pc take the xbox lead out and just have the pc connected and see how the picture is.
if ok it could be a interference with the xbox360 so just make sure its switch off.....
