godsie,
I use a ATI 9600 on a Panasonic TV no problems:
Step by step:
1) Right click PowerStrip tray Icon and choose "Display Profiles ->
Configure"
A screen opens
2) Click on "Advanced timing options"
A new screen opens
3) Click on "Custom Resolutions"
A New screen opens
4) Click buttons under list on left to be "User Defined"
5) Copy the following between the ================ and =============== to
the clipboard as if you were going to paste it into notepad ( don't copy the
PowerStrip timing parameters:
1024x576=1024,88,48,160,576,1,5,43,20559,41
Generic timing details for 1024x576:
HFP=88 HSW=48 HBP=160 kHz=16 VFP=1 VSW=5 VBP=43 Hz=25
Linux modeline parameters:
"1024x576" 20.559 1024 1112 1160 1320 576 577 582 625 interlace +hsync +vsync
6) To the right, bottom of the current PowerStrip screen is a suitcase
button -> click it and the stuff you have just copied to the clipboard is
put into all the correct places in PowerStrip
7) Click on the "Add New Resolution" button
PowerStrip will add the settings to the left list but will probably also say
it needs to reboot windows. Click any "OK" buttons to let it reboot.
8) After reboot you will have an 1024x576 resolution option off the
PowerStrip right click "Display Profiles" which you can choose
( If it is not off the right click then do:
a) Right Click "Display Profiles -> Configure"
b) use the Resolution slider at top right so pull slider to 1024x576
c) click any "OK" buttons and resolution will change
Once 1024x576 is chosen, then your VGA-SCART input on the TV should
stabilise with a centralised image of resolution 1024x576 with about 8
pixels lost on each side due to overscan.
You may possibly also need to turn tiling OFF for stabilisation. It is better to have tiling ON but if you can't get a stable picture with tiling ON then you will have to turn it off.
To do that:
Configure"
A screen opens
A new screen opens
A New screen opens
4) Double click the words "New Resolution" in the heading at the top right.
The tiling requester opens and you can turn tiling OFF.
5) Click any "OK" buttons to get back to the desktop.
6) You may need to reboot at this point and then choose something other than the 1024x576 resolution and then *choose* the 1024x576 resolution.
Best of luck.
