VGA -> RGB SCART - pinout question which site is right?
Discussion in 'Desktop & Laptop Computers Forum' started by jonsayers, Mar 17, 2005.
  1. jonsayers
    jonsayers
  2. Dunkwho
    Dunkwho
    Sep 3, 2001
    531
    28
    Dunstable
    +24
    I used the second one ... works fine with my 9600 to my sony 25" 4:3 50hz, and panasonic 32" 16:9 100hz. The only difference is the function and blanking line coming from the vga socket.
    Duncan
  3. gordonfmoore
    gordonfmoore
    ditto
    the first one doesn't have the audio and uses a +5v supply from the powersupply.
    The second one has been updated, so earlier posts to the effect that it was incorrectly wired are no longer true:
    Read through these forums and threads:
    http://www.avforums.com/forums/showthread.php?t=136811&page=1&pp=15
    http://www.xpmce.com/forum/viewtopic.php?t=92596&start=0&sid=02dceb1b9737bc65106a328d9f5fd0b0
    And it is worth the effort in terms of quality. I'm having to use s video temporarily as I rebuild my system and its awful.
    Gordon
  4. jonsayers
    jonsayers
    cheers. re-wired to the second method and it worked fine. (sort of LOL)
    Just to get the resolution/timing right. Screen keeps scrolling at the moment.
    I'll have a good read through those threads later. Anyone know the best resolution and timing for a 16:9 TV?
  5. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Anyone ever tried this Scart wiring with an NVidia card (i.e. 6600GT)???? Everyone always mentions ATI cards with this so I'm curious if it works with NVidia cards???????
  6. stlic
    stlic
    Feb 17, 2004
    769
    +19
    nVidia cardas cannot output a composite sync signal so the above lead would not work. You could, however, use this lead; no personal experience so can't really advise you further.
