VGA question
Discussion in 'Blu-ray & DVD Players & Recorders' started by Melvin, Aug 1, 2004.
  1. Melvin
    Melvin
    Jun 28, 2001
    79
    Stoneleigh
    +3
    I would like to plug a DVD player straight into a high quality computer monitor. Are there any DVD players out there that have vga outputs ?
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    The Momitsu V880 has a DVI-I connector which will output both digital and analogue RGB. Hope this helps.
    Steve
  3. bjarneh
    bjarneh
    Jul 28, 2004
    Gothenburg
    Many players have RGB output on the scart connection.
    Would a scart-vga interlink cable do the trick?
    Or is the signal standard different or something?
    /Bjarne
  4. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    VGA has separate H and V sync - RGB Scart has sync on composite. Hope this helps.
    Steve
  5. dean randle
    dean randle
    Jan 9, 2003
    156
    UK (Bromley)
    +6
    Maplins do a tangent player with vga for £50, if that's any use to you (400 model i think?).
    Dean.
  6. Melvin
    Melvin
    Jun 28, 2001
    79
    Stoneleigh
    +3
    Guys,
    I am sorry that it has taken me so long to respond. Thanks for all the leads that you have put my way. I will follow some of these up.
    Once again, cheers.
