VGA or S-VGA cable?
Discussion in 'Plasma TVs' started by spook, Sep 27, 2004.
  1. spook
    spook
    May 18, 2004
    157
    I am putting in my order for a JS scart RGB to VGA convertor, just wondering would there be any advantage to using an S-VGA cable from the box rather than VGA, I believe they have better screening, am I correct?.
    also would I see any difference if I used a RGB only scart lead (something like the QED one) to go from my Sky+ to the JS box?
    cheers, Spook
  2. AV Junky
    AV Junky
    Oct 30, 2002
    1,209
    Cheshire, UK
    +68
    S-VGA cable? If you mean that you are thinking of buying a better quality VGA cable with better screening, then yes it sounds like a good idea, particularly if you have a long cable run.
