^ Which will ive me the better picture quality with my 360? Thanks Batch
B Batch Prominent Member Oct 16, 2005 #1 ^ Which will ive me the better picture quality with my 360? Thanks Batch
N neil c Established Member Oct 16, 2005 #2 You need to let us know which TV you have before you will get a decent answer. If your TV can show Hi-Def signals on a VGA input, then use the VGA. If it can only show standard PAL signals then use RGB scart.
B Batch Prominent Member Oct 16, 2005 #3 Ive got this one: http://www.samsung.com/uk/products/monitors/lcd/sm910mpxeu.asp Thanks Batch
B brain_stew Established Member Oct 16, 2005 #4 Batch said: Ive got this one: http://www.samsung.com/uk/products/monitors/lcd/sm910mpxeu.asp Thanks Batch Click to expand... VGA, you should get 720p with borders at the top and bottom on that, it will look very nice indeed.
