VGA or DVI cable
Discussion in 'Projectors, Screens & Video Processors' started by hal5, Jun 11, 2003.
  1. hal5
    hal5
    Currently a newbie to this stuff and I am about to take the plunge and buy a projector - probably the Panasonic AE300 .
    I have a HTPC and was looking to have 2 outputs consisting of 1 to the projector and 1 to a TFT monitor, my question is -
    Should I use a DVI cable or VGA cable to the projector (What will give me the best quality or are they the same)?
    If it happens to be VGA then can I use the DVI output to the TFT using an adapter into the VGA slot on the TFT (approx 7.5meters)?
    Your help is appreciated
