VGA Not being seen
Discussion in 'Cables & Switches' started by vpresti, May 10, 2005.
  1. vpresti
    vpresti
    Hello
    I have search for an answer and cannot find one. I made a VGA cable using 15 Conductor with a shield and a ground. I checked continutiety on each pin and its all good. When i connect it from my laptop to a monitor ( LCD ) when i go to hit "FN F7" to switch monitors, it does not recognize another monitor. If i use a factory made VGA cable, it works fine though. I made the VGA cable a straight through cable just like the factory made one and even ripped out the #9 pin.
    Now if i connect the factory VGA cable, and get the desktop to show on the LCD monitor; then while its still up, i switch the cable to the homemade VGA cable, i see the desktop on the LCD but it has a HARD red tint to it but still "FN F7" still dont recognize an external monitor.
    Can anyone please help me and tell me if i did something wrong? I am good at making wires, but this is the first VGA cable i made.
    Thank You
  2. severnsource
    severnsource
    Jan 19, 2003
    322
    +9
    Have you checked for shorts between pins? It's very easy to get shorts on standard D types, let alone the HD ones.
    Bill
