VGA Lead
Discussion in 'Cables & Switches' started by lee_car, Aug 18, 2005.
  1. lee_car
    lee_car
    May 16, 2005
    579
    Oldham
    Can anyone recommend a decent VGA cable for £30-£50, for use with js converter - panny pw7
    Cheers Lee
  2. andrewb0000
    andrewb0000
    Aug 13, 2005
    74
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,909
    The Borders
    +3,126
    Hello both
    VanDamme Red Series or BetterCables Silver Serpent HD15 work well with the JS Tech converters - though both are a little outside your indicated price range.
    JS Tech supply and recommend the VanDamme Blue Series VGA which are within your indicted budget.
    Best regards
    Joe
    PS John Sim of JS Tech uses BetterCables :)
  4. andrewb0000
    andrewb0000
    Aug 13, 2005
    74
    hi joe
    do you sell the vandamme cables? if so how much are the red and the blue?
    thanks
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,909
    The Borders
    +3,126
    Hello Andrew
    I'll drop you a PM.
    Best regards
    Joe
  6. Fat Tony
    Fat Tony
    May 1, 2004
    644
    +20
    Hi Joe,
    I am after a VGA to VGA cable for running between a JS Tech box to a Panasonic PW6 screen. 1m-2m length would be sufficient. Can you please quote me for a Bettercables Silver Serpent and VanDamme Red/Blue. If you could also indicate what improvements I could expect between each of those, that would be really appreciated.
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,909
    The Borders
    +3,126
    Hello Fat Tony
    You have a PM.
    Joe
  8. SillySausage
    SillySausage
    Jul 10, 2004
    596
    Leicester
    +14
  9. Fat Tony
    Fat Tony
    May 1, 2004
    644
    +20
    Thanks all.
    I was really tempted by the write-up's on the Bettercables Silver Serpent, but the Lindy looks pretty good, and for around £20 I will give it a go (... will keep 'er indoors from throwing a wobbly, as she thinks no cable should be more than a fiver!).
  10. cab0210
    cab0210
    Can anyone give me some advice on connection option for a laptop with only VGA output. I would like to use the DVI PC input on my Hitachi 32LD7200 LCD TV but is there much point if connecting to a VGA port on the laptop? You can buy adaptors to convert VGA to DVI and then buy a dvi-i to dvi-i cable to connect but I am wondering if this is worhtwhile or I would be better off getting a cheaper VGA/D-sub cable. Can anyone offer any suggestions?
  11. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,909
    The Borders
    +3,126
    Hello cab0210
    If your LCD TV has an HD15(VGA) Input then there is nothing to be gained by connecting the HD15(VGA) Output from your Laptop to the DVI-I Input on the LCD TV; both Inputs are working with the Analogue RGBHV signal from your source.
    Best regards
    Joe
