VGA lead Switch?
Discussion in 'Cables & Switches' started by dinoprada2003, Aug 17, 2004.
  1. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    4,032
    2
    LONDON
    +6,824
    Hi All,
    Im going to be running a VGA lead from the back of HTPC to my PJ.Thing is Pc' is also used for web,surfing,reading A/V forums etc.etc ;) So I dont really want to keep taking monitor lead out of back of my HTPC everytime I want to use the PJ! Is there some sort of "switch box" I can buy? If it helps? my projector has a VGA Input and VGA output My HTPC has VGA out and a DVI socket.
    Cheer's
    DINO.
  2. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    4,032
    2
    LONDON
    +6,824
    Found a switch box myself online :D
    http://cgi.www.revealcable.co.uk/Large/1700/aa_1700.htm
    However being the donought that I am I didnt realise that my graphics card's DVI out,came with a toggle converter I.E connect PJ to PC via DVI 2 VGA converter dohhhhhhhhhh.......... :blush:
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,749
    The Borders
    +3,286
    dinoprada2
    The switch you've linked to is pretty rudimentary and not ideal if running at a decent resolution - if you did need a box I'd have suggested the Kramer VP-200XL Distribution Amp.
    See http://www.kramerelectronics.com/indexes/desc.asp?p=VP-200xl
    The VP-200XL has 1 Input and 2 Outputs - and importantly Variable Line attenuation to drive the long cables that normally go to ceiling mounted projectors.
    Best regards
    Joe
  4. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    4,032
    2
    LONDON
    +6,824
    Nice one Joe,glad I didnt need to buy one in the end though! :D
    Best Wishes
    Dino.
