VGA Lead Question (JS Tech box to Panny PW6 Plasma)
Discussion in 'Cables & Switches' started by internetuser, Jan 17, 2005.
  1. internetuser
    internetuser
    Jul 17, 2003
    3,464
    +247
    Currently I am using a normal PC VGA lead (new ish lead from a 17" LG TFT) to link my Plasma (Panny PW6 to the JS Tech box)
    Is it worth changing the VGA lead for a more expensive one, or will the one I currently run do the job ? And would I notice a difference if I changed it ?
    If a better one is called for, what type should I get ?
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    if you can see "ghosting" replace it
    If you can't, its as good as it gets, so stay with it.
