VGA -> iScan HD
Discussion in 'Cables & Switches' started by kevshed, Jun 27, 2004.
  1. kevshed
    kevshed
    Oct 30, 2002
    1,248
    48
    bournemouth
    +98
    Looking for some advice from the experts again :D
    I have a PC in my living room, that i would like to run through my iscan HD. But heres the problem.
    The PC only has VGA output (and i cant change the video board to one that has DVI)
    The only inputs i have on the HD that will deliver the quality i want, is the component.
    So, is it possible for me to connect VGA to this Component input (presumably some type of converter is required).
    The whole reason that i need to do this, is that currently the PC is connected directly to the reciever box for my pioneer 434 - but because the connector is on the front of the box, the installation is not WAF friendly.. hence i need an altertantive.
    Any help appreciated.
    thx
    Kev
