VGA into LG14 Plasma?
Discussion in 'Plasma TVs' started by TP2K, Apr 4, 2003.
  1. TP2K
    TP2K
    Nov 14, 2002
    523
    16
    Since I now know that the JS VGA box is no use for the LG14 plasma, is there anything else on the market with the correct frequency output that I can use?
    Or are we unable to connect DVD to this particular plasma via VGA?
  2. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    You could try an external scaller such as the iScan. Otherwise, consider RGB to Component converters.
    All the best,
    Dr John Sim.
  3. TP2K
    TP2K
    Nov 14, 2002
    523
    16
    What sort of improvement would be gained using a Component converter? I already connect using component as it happens, and am curious as to what benefits I will see.
