VGA HD AV Cable + Plasma
Discussion in 'Xbox Forums' started by soobydude, Mar 17, 2006.
  1. soobydude
    soobydude
    Will I see a big difference on my 42" HD plasma with the VGA HD AV Cable vs. the stock Component HD AV Cable?
    Thanks.
  2. Anotherlimey
    Anotherlimey
    Nov 6, 2005
    6,113
    2
    Portsmouth
    +930
    I bought a VGA and on my 42 plasma is looks stunning compared to the bundled cable that came with the premium..... However i bought a 32 LCD for my little play room and VGA looked awful on it, Maybe LCDs dont handle VGA well, Who knows :confused:
  3. daveblade
    daveblade
    Apr 2, 2005
    366
    +15
    i got one of these last week for my toshiba wlt 58 after playing through componant and i thaught it was atleast the same then i saw ghost recon in game on a sammi lcd and it was so much more crisp i think i may have to go back to swopping cables over as my dvd player is in componant just compair befor you buy if you can im not happy with mine:thumbsdow
    dave
    ps mine is lcd
    i took the cable back to hmv today i told them it was not working atall after i checked they had none in stock after a little humming and arring they gave me my money back
    componant in my opinion is not just a little but a lot better be warned
  4. soobydude
    soobydude
    Hmm, I wonder if it is worth the $50 for the cable...
