wellibob
Established Member
Dear viewers, i recently connected my 32" lcd tv to my pc, along with my normal monitor, and the tv itself is connected through a 7.5 meter belkin vga lead. Ive now got ghsting on the image on the LCD tv image (its fine on the normal tft monitor with its normal vga lead supplied). The 7.5 meter vga lead does not have what i assume are ferrite rings around the cable at both ends like my normal vga leads that connect to my pc monitors. Is it possible for me to get some ferrite rings to stop this interference on my 7.5 lead (by wrapping the lead around them), or simply get another long vga lead with the protection built in ?
The said 7.5 m cable is now under the carpet, and its going to be a pain to remove it, thus a fix rather than a new lead would be helpful. Using my normal vga lead (with rings) and a vga ext lead does not produce this ghosting image on my HDTV(1360x768) , but the lead isnt long enough, and a pain to put onder carpet anyway
