VGA extension cable or component?
Discussion in 'Projectors, Screens & Video Processors' started by agendrano, Nov 10, 2003.
  1. agendrano
    agendrano
    Aug 27, 2003
    24
    I will be connecting my Infocus X1 to my pioneer DV655A using the component output. The X1 will be ceiling mounted and I need to use an extension cable.
    My dilemna is: Should I get component cable extension or a VGA cable extension? (The X1 uses a VESA to component adapter, I was thinking to install a VGA extension cable between the projector and VESA to component adapter or another option would be to use a component cable extension between my DVD player and the VESA to component adapter of the X1).
    Thanks!
  2. Kramer
    Kramer
    Pretty much down to which is more convenient, looks better & you prefer.
    Good quality VGA cables available from Lindy at reasonable prices.
    No real-world difference between VGA/component in this situation as you're sending the same signal.
    :smoke:
  3. Paul Williams
    Paul Williams
    Jul 4, 2003
    821
    Plymouth/Devon
    +18
    Hi agendrano
    is the DV655A a progressive output machine? The VGA input is used for this. For an interlaced output you will need to go via the X1's modified S-Video input with their adaptor for a component signal.
    Paul
  4. agendrano
    agendrano
    Aug 27, 2003
    24
    Paul
    The 655A is a progressive DVD player.
    Thanks for the info.
    Alex
