VGA -> DVI converters for GA4
Discussion in 'LCD & LED LCD TVs Forum' started by aver, Jan 8, 2005.
Tags:
  1. aver
    aver
    Dec 4, 2004
    3
    I want to drive my GA4 using a 15 pin VGA cable, I can find a whole load of cheap converters on ebay, but I'm concerned that it won't be able to fit inside the case when the converter and the vga cable are connected.
    Does anyone have this working, and if so, where did you get your converter?
    Thanks,
    Aver
  2. Skiny
    Skiny
    Aug 18, 2004
    287
    19
    Can't you use a DVI cable, and put a DVI>VGA converter on the end of that?
    How come you want to use VGA instead of DVI?
  3. aver
    aver
    Dec 4, 2004
    3
    I already have a 15 foot VGA cable to hand (so I don't really want to buy a long DVI cable quite yet), and the DVI output on my PC is being used for the monitor, but it does have a spare VGA connection which means I should be able to have both on at the same time.
  4. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    you can get one for a 10 er yer cheap ***** :)
