VGA Connection
Discussion in 'Blu-ray & DVD Players & Recorders' started by 3000gto, Mar 28, 2006.
  1. 3000gto
    3000gto
    Jan 18, 2006
    1,171
    Edinburgh
    +108
    I have a LG RZ23LZ20 Lcd TV that has a vga input (RGB-PC)
    If i was to buy a dvd player that has a vga output (ie SIGMATEK XMB-510 High Definition DVD/DivX player or the PEEKTON PK 6006) woudl i be able to plug the dvd player directly into the tv using a vga cable ?
    I currently have a Philips 720sa connected to the tv via svideo but would rather take advantage of the tv's pip etc if possible.
    Any help appreciated
    Paul
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    You would need to check what resolutions and refresh rate are supported via VGA and see if it matches the output of the player, though in theory it should work.
