VGA Connection
Discussion in 'Satellite TV, Sky TV & FreeSat' started by mcgibbon85, Sep 23, 2005.
  1. mcgibbon85
    mcgibbon85
    Sep 19, 2005
    46
    I was just messing round with the scarts on the back of my Sky box and noticed a VGA connection there, is it possible to use a VGA connection to hook this upto my LCD tv?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    It was probably the RS232 interface, not VGA:)
  3. mcgibbon85
    mcgibbon85
    Sep 19, 2005
    46
    doh never mind just think the picture on my Samsung LCD is pretty rubbish through scart
  4. SeanT
    SeanT
    Jan 28, 2005
    6,163
    Coventry
    +368
    You can get Scart - VGA converters, Scart - component converters and some DVD recorders have RGB Scart inputs and component outputs to run it through
    Or you could head for a cheap scaler ;)
  5. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Remember that bitrates across all the channels on Dsat do vary quite alarmingly and most really do not like being enlarged to match the resolution of the LCD.
    Some LCD's do a better job of this than others which is one of the weak points in buying a HD panel for SD digital broadcasts. A better scart cable may help and the price of a RGB to component may be too high for a marginal increase component could offer. Basically if the source material is poor and the display scaling engine is not good then no money on a better connection is going to make up the difference:(
    DVD I suspect looks very good even via scart let alone component.
    HD of course will blow DVD out of the water:)
