VGA connection to HS10
Discussion in 'Projectors, Screens & Video Processors' started by rooster, Jan 18, 2003.
  1. rooster
    rooster
    Mar 18, 2002
    224
    Edinburgh
    I ordered a standard 15pin Dsub vga cable ahead of my pj purchase on the assumption i was going to get the Sanyo Z1. I have since changed my mind and will be buying the HS10 which needs a different connector. I am going to be installing cables over the weekend and then plasterboard will be going over them. Not sure if its worth putting the cable in now as i t cant be used as it is. Though there may be some sort of connector that can marry this cable to the HS10. Anybody heard of such a connector?or would i be just as well to flog it.
  2. Kramer
    Kramer
    Useless for the HS10 :( Flog it (offer "nicely" in the FS forum here).
