vga connection query.
Discussion in 'Cables & Switches' started by grahamd, Nov 16, 2004.
  1. grahamd
    grahamd
    Jul 4, 2002
    73
    norfolk
    i have a keene scart commander which feeds a jstech rgb to component converter from the scart output to a pj.
    i want to add a plasma screen (pwd6), will the vga output on the scart commander (15 pin hd connector) be compatable with the vga input on the plasma.
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    Yes for the PW6 (VGA input takes RGBHV or component)
    No for the PW7 (VGA input takes RGBHV only)
