VGA -> Component
Discussion in 'Cables & Switches' started by rscott4563, Jan 8, 2004.
  1. rscott4563
    rscott4563
    Jan 21, 2003
    1,051
    38
    Cumbria
    Any idea where I could get a VGA -> Component cable, I'm only after a basic cable for a low price as it will only be a temporary measure for about a month or two??
    Cheers :smashin:
  2. pemberto
    pemberto
    Oct 14, 2003
    500
    28
    Huntingdon
    +32
  3. rscott4563
    rscott4563
    Jan 21, 2003
    1,051
    38
    Cumbria
    Had a look but couldn't see anything like a vga to component cable??
  4. rscott4563
    rscott4563
    Jan 21, 2003
    1,051
    38
    Cumbria
    Anyone else?? :confused:
    :smashin:
  5. JRHAY72
    JRHAY72
    Keene.co.uk do them but they are not cheap.
    Check product codes SBB402, SBB404 or SBB405 on their website.
  6. rscott4563
    rscott4563
    Jan 21, 2003
    1,051
    38
    Cumbria
    Thanks for the help, unfortunately I've just got myself one from Loonatic on the classifieds and it was even more expensive than the one's you've found, but it is a very good one and so I can always sell it on in a month or two when I've finished with it....
    Nevermind, thanks for the help anyway. ;) :smashin: :hiya:
