Okay so here's the deal: I'm trying to split a VGA cable/signal from an XBOX 360 console.
1 out must go the the tv/monitor.
1 out must go to a component capture card.
I will be using a HD VGA cable from the Xbox 360 as my source.
I plan to use this splitter:
For only $13.84 each when QTY 50+ purchased - 2-Way SVGA VGA Splitter Amplifier Multiplier 400 MHz - Black | 2 Way Active/Powered VGA / SVGA Splitters
1 vga cable will go to the monitor the gamer will play on.
The other signal will need to be converted to component. I plan on using this cable:
For only $2.35 each when QTY 50+ purchased - 6FT VGA to 3 RCA component video cable (HD15 - 3-RCA) | VGA to 3 RCA Component Cables
Then go into my capture card the "HD-PVR":
HD PVR Product overview
The HD PVR accepts both YCrCb or YPrPb.
Will this set-up work? I've been told that the vga/component cable may be a problem.
Any help would be greatly appreciated!
Also I need to be able to expand on this system as eventually I'll need to have 8 xboxes and tv's daisy chained for live switching and controlling.
-Lance
-Lance
