VGA Component or Component Board?
Discussion in 'Plasma TVs' started by coolmp3, Jan 6, 2005.
  1. coolmp3
    coolmp3
    Dec 27, 2004
    317
    +22
    I Have had my Panny PWD6 for over a week now. I orginaly purchased the Samsung PS42D4 which went stright back once i switch the thing on Total crap. The picture on the Panny is Great i could not ask for more. Any way back to the question in hand.
    I have made a VGA to Component Cable using a good quailty cad monitor cable and cut of the BNC's and fitted my own Gold rca's on. I wonder if anyone can tell me if i would get an even better picture using a component board. I current just have the standard VGA and a scart board. Also i have got my NTL Digi box running RGB in to my Sony HX900 recorder which is then outputing Component. I The picture looks great but is this the best option?
    Cheers Peeps.
  2. Barend
    Barend
    Apr 12, 2004
    804
    +9
    If I remember correctly from a very old posting when you use the VGA input (same R-G-B analog feeding really) you don't have the JUST mode.
    Not sure though. will try hooking up my new Iscan thru 2 x HD15 this weekend.
