VGA cable to plasma via conduit
Discussion in 'Cables & Switches' started by t0by, Nov 2, 2005.
  1. t0by
    t0by
    Jul 27, 2004
    455
    Hertfordshire
    +7
    Hi folks
    I need to run a VGA cable to my PW7 via a round piece of conduit that is around 2cm in diameter. Most standard VGA cables are too big to fit through.
    Can anyone point me in the direction of either (a) a cable that has a smaller connector on the end, or (b) a cable that you can 'break apart' to feed it (eg. like this, but which I can source in the UK)
    Thanks in advance
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,525
    Kent
    +830
    I would beware a detachable cable like that, could pull apart within the wall and take ages to fish out and re-lay!! Is this conduit already buried? If so I think you're only choice is going to be to solder the end on on-site. Or, go to the expense of using CAT5 sender/recievers. CAT5 will fit down the conduit, but then you will need to hide the receiver somewhere behind the plasma.
  3. t0by
    t0by
    Jul 27, 2004
    455
    Hertfordshire
    +7
    The conduit isn't hidden in the wall, Liam (check the PW7 link in my sig). Its just a couple of hollow poles that I use to make the cabling look tidier, so a detachable cable won't be a problem.
  4. NonPayingMember
    NonPayingMember
    Oct 18, 2002
    8,525
    Kent
    +830
    In that case run 10x20mm trunking (which you can pop apart to put the cable in) and finish with B&Q silver radiator pipe cover. Looks just the same as what you've got there!!!
