VGA cable to plasma via conduit
Discussion in 'Plasma TVs Forum' started by t0by, Nov 2, 2005.
  1. t0by
    t0by
    Jul 27, 2004
    455
    Hertfordshire
    +7
    Hi folks
    I need to run a VGA cable to my PW7 via a round piece of conduit that is around 2cm in diameter. Most standard VGA cables are too big to fit through.
    Can anyone point me in the direction of either (a) a cable that has a smaller connector on the end, or (b) a cable that you can 'break apart' to feed it (eg. like this )
    Thanks in advance :smashin:
  2. Fossil
    Fossil
    May 29, 2005
    105
    +5
    I had a similar problem, the cable needed to go through 3 walls from my pc to the living room where the plasma is. I didn't want to drill massive holes in these walls for the plugs so I decided to cut the cable and reconnect!!!!! lol. It was a bit of a nightmare (15 smaller cables inside and 3 of those were mini coaxes with 3 cores). In the end it was easy though time consuming to connect them all up again but it saved me drilling such big holes.
  3. av2diefor
    av2diefor
    You could try vga over cat5.
