Vga Cable To Philips PLASMA
Discussion in 'Philips TVs Forum' started by patmyhead, Sep 7, 2003.
  1. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    hi
    i am about to get the philips with pixel + & need to get a 5m vga cable to conect screen & tuner any one recermend a good quality vga cable
    also is it male to male/female or whatever
    any help much appreciated
    [email protected]
  2. jmack
    jmack
    i use a vandamme vga cable for my plasma and its very good quality. there is also better cables from joe at tfm that are supposed to be very good.
    i have a 5m vga with 2 phono`s for audio attached left over from my old philips plasma.
    i might be willing to sell;) ;)
  3. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    hi
    what sot of qualityis your lead ?& how much for you to part with it is it male to male required to conect the philips
    thanks for reply
    [email protected]
    :hiya:
  4. jmack
    jmack
    i will post it in the for sale forum and a picture so all can see and to stick by rules ok.
  5. pixie
    pixie
    Aug 30, 2002
    41
    Bristol
    You may want to check what vga cables come with the panel before purchasing separately, as it probably comes with 2m and 5m cables included (my Philips 9964 had these in the box).
    pixie
  6. yasa22
    yasa22
    Jan 14, 2003
    67
    Uk
    It comes with 2 and 5M leads, although they are not as good quality as the ones that came with the 42PF69964
  7. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
