VGA cable quality advice needed
Discussion in 'Cables & Switches' started by lhough20, Oct 14, 2004.
  1. lhough20
    lhough20
    Just wondered if theres different quality of VGA cables as theres obviously is with scarts, components and speaker cables, etc. I'm currently using a standard VGA cable that i think came with the video scaler. Is this ok or would an investment in a "good quality" one make a difference?
    Just wondering as the rest of my setup uses decent quality cables and this is the only one that i haven't changed.
    Thanks for any help
    Lee
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,410
    The Borders
    +3,228
    Hello Lee
    A 'decent quality' five core video Multicore terminated in HD15 (VGA) hoods can make a fairly significant difference in your set up - especially so once you start to use a scaler to output higher resolution signals.
    We supply a range of cables on sale or return so you can try one in your system before you part with your cash.
    Drop me a PM if you want further info.
    Best regards
    Joe
