VGA cable: picture quality differences?
Discussion in 'Plasma TVs Forum' started by thfcwestlower, Sep 26, 2004.
  1. thfcwestlower
    thfcwestlower
    Sep 26, 2004
    186
    +11
    Hi guys,
    Im new to this forum and would be extremely grateful if anyone could help me with a question.
    Im looking to run a console (PS2) into a JS Tech RGB - VGA converter and then run a length of VGA - VGA cable up into the 15 pin socket on the TH-42PWD6. However, will I notice a significant difference in picture quality between, for instance, a Van damme cable (c.£60) and a generic VGA - VGA cable purchased from Maplin (c.£10!).
    Sorry if this seems a stupid question, but I thought that £60 is pretty steep for VGA cable! I am expecting the more expenisve cable to exhibit better quality picture, but does the difference justify the price difference?
    Thanks in advance for any responses.
    Antony
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    not all cables are equal. A lot of VGA cables seem to be unscreened, and if you buy
    one of those the picture is pooh. The Belkin Pro High Integrity cables are excellent.
    I have one on my JS box to PWD6 and if you buy it from here, a very good price.
    5m for £9
    http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=21883
    3m for £8
    http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=21885
    DO NOT buy the ones that don't say "High Integrity" as they are unscreened
  3. thfcwestlower
    thfcwestlower
    Sep 26, 2004
    186
    +11
    Im going to order the 5m version right now!
    Thanks for the recommendation.
