VGA Cable - performance increase in proportion with cost?
Discussion in 'Cables & Switches' started by rwttm001, Jan 2, 2007.
  1. rwttm001
    rwttm001
    Sep 25, 2006
    1,811
    Leeds
    +118
    Hi guys
    Hook my plasma up to Sky via JS Tech RGB2VGA box, currently using a cheap Belkin PureAV VGA cable. Have seen the BetterCable silver serpent for £60 on Mark Grants site and the Van Damme Red Series for £32 on Av-Sales, would I see a mark improvement in PQ by switching to either of these? Is a VGA cable ultimately just a VGA cable (as some say about HDMI cables)?
    Thanks a lot:hiya:
  2. HD3
    HD3
    A HDMI cable is a HDMI cable, VGA cable choice can make a difference.
    Although the Belkin is nothing special, it is likely to be of a reasonable grade. Certainly nothing wrong with it.
    Depending on the length of the cable you shouldn't really find a more expensive one any better.
    Its up to you, a more expensive cable is not a bad thing. But 60 pounds is overkill.
