mark raeburn
I have drilled a hole through my chiney breast with which I have fed my component and s-vhs cables through, the problem I have is that I now want to feed a VGA cable through however the diameter of the hole is about 1 inch, to narrow for the male VGA connector with screw holes either side to fit through.
Anyone got any ideas how to get rounf this? Is it possible to get narrow VGA connectors ie. not much more width than the actual plug?
Mark
Mark
