VGA cable for pc..from an infocus pj ..Help!
martian1
Joined
Dec 30, 2001
Messages
2,813
Reaction score
793
Points
730
Age
59
Location
Sunderland
I want to pre instal a cable for my pc into wall, i understand the infocus projectors need a special M1 connector. Is a VGA connector the same as a DVI :confused:
I want to plumb projector into pc via VGA How do i do this? Do i just buy a standard VGA lead and then get the M1 connector plug it into VGA lead then other end goes into projector,or do you have to get a special lead with VGA one end M1 other?..Help appreciated :smashin:
The Infocus comes supplied with a VGA to M1-DA cable. The Infocus projectors have an M1-DA socket which needs an adapter to connect to DVI, HDMI or VGA. Alternatively, instead of buying an adapter, you can buy a cable with the M1-DA at one end and whatever you require at the other. But on new Infocus projectors, the M1-DA to VGA is supplied although it's only about 1.5 metres long.
Thanks :smashin:
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
