VGA-BNC cable to Panny PW7 question?
Discussion in 'Plasma TVs' started by RockSteddie, Sep 9, 2005.
  1. RockSteddie
    RockSteddie
    Mar 26, 2005
    1,122
    +130
    Hi All
    Could I use the following cable from my PC Vid card (Radeon 9800 Pro) to a spare component input board on my Panasonic PW7 Plasma ?
    http://www.tvcables.co.uk/cgi-bin/tvcables/VGA-BNC.html
    I want connect my PC to my Plasma but my VGA slot is already in use.
    If the above doesnt work are there any alternatives?
  2. nak
    nak
    Dec 20, 2004
    146
    Birmingham
    +12
    Hiya,
    That lead will not work on the standard single slot component boards as there will be sync issues.
    It should work on the dual slot board here
    ...but you may be limited in which screen modes you can use.
    Someone will hopefully set us straight if they have these connections.
    :smashin:
