zad
My current Philips tv is getting old in the tooth, so I keep looking at getting a 55" OLED. I'm also in the middle of planning a floating wall as the plaster is cracking and I want to hide all cables but I think the VESA mount points are off set on OLED's? I was going to stick the mount right in the middle thinking that would do but then saw a picture which suggested otherwise.
Can some one help and give me the measurements from the top of the screen to the top holes and then the bottom to the bottom holes please I can't afford to go get the tv just now so need to do a template.
