Vesa mount for Samung lw26a33w?
Discussion in 'Home Cinema Buying & Building' started by iMark, Jul 19, 2005.
  1. iMark
    Hello, I'm, looking for a wall mount for a samsung lw26a33w. The manual's a bit vague on the subject of vesa mounts in general, but after a bit of measuring around the back I'm pretty sure that a 200 x 100 mount will fit. I thought something like http://www.chaseavdirect.co.uk/acatalog/LCD-TFT-Wall-Mount-Artic.html might work with an adaptor plate. It does say it's only suitable for screens up to 23 inches, but the samsung without the stand weight less than the 15 kilo threshold. Any ideas if this sort of thing is ok? I'm certainly open to suggestion if you're aware of any alternatives.
