VESA Mount And Wall Sockets
Asif1392
Hi all. Got a bit of a dilemma. I have an extension wall that I would like to mount a tv on. I can’t go bigger than a 50 inch (hasn’t been purchased yet, was hoping for a Hisense due to budget constraints). The issue is that the wall sockets are positioned in such a way that the vertical mount brackets must be 400mm apart. A 200mm or 300mm space between the brackets will cover the sockets. Moving the sockets is not really an option and I cannot find a TV up to 50 inches that has a vesa width of 400mm. Alternatively I haven’t managed to find an adapter that can be attached to the tv that will ‘increase’ its VESA width. Any help would be appreciated.
Asif1392
Hi, thanks for reply. It has been installed about the sockets. The issue is more about the vertical brackets that will run over the sockets. To be honest, my cunning plan is to swap the sockets for the ultra thin versions which will reduce the impact on the brackets (hopefully).
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
