Vesa Measurements?
Discussion in 'LCD & LED LCD TVs' started by busterdan, Jun 8, 2005.
  1. busterdan
    busterdan
    Aug 18, 2004
    1,346
    48
    SE London
    +37
    Probably a really obvious answer to this....
    But in measuring the mounting points on a Vesa supported panel.... how do you determine the correct size use?
    Assuming there are four holes on the panel, do you measure the distance between the two horizonal holes.... so for example that may be 200mm, or do you measure between the two holes vertically.... which may be 75mm or do you measure horizontally to the centre between the holes... so that may be 100mm?
    I've assumed it is the measurement horizontally to the centre.....so in this example a 100mm Vesa mounting would suffice....
    Am I wrong?
  2. SteveW70
    SteveW70
    Unfortunately you are :(
    Measure Horizontally between holes and vertically between holes to give you your Vesa size :smashin:
    i.e:
    If the holes are 75mm apart H&V then this is Vesa 75
    If 100mm apart H&V then Vesa 100
    If 200mm apart H and 100mm apart V then Vesa 200/100
    If 200mm apart H&V then Vesa 200
    Hope this helps. :thumbsup:
  3. busterdan
    busterdan
    Aug 18, 2004
    1,346
    48
    SE London
    +37
    Just the clarification I needed mate....nice one :smashin:
