Vesa 200/100 wall bracket
Discussion in 'Home Cinema Buying & Building' started by tasaf, Feb 28, 2005.
  1. tasaf
    tasaf
    I am looking for a low profile Vesa 200mm x 100mm wall bracket. I scanned the web and I found out mainly that I should use adaptor. I also found that Ergotron FX75 might be a good solution. I have LG 32" and LG do not sell wall bracket for their products. Can I use wall bracket from other companies, like Toshiba or Pannasonic ? I am just about to throw it away ! Please help.
  2. sin_chase
    sin_chase
    Feb 24, 2005
    28
    Correct me if I am wrong but VESA stands for "Video Electronics Standards Association"
    being a standard as long as your LG needs a VESA wall mount and you buy the correct dimension for your panel you shouldnt have an issue using any VESA rated mount.
  3. tasaf
    tasaf
    VESA is indeed a standard, but it seems that the bracket manufacturers do not make the VESA 200/100 low profile mount. VESA 75 and VESA 100 are very popular.
  4. alscds
    alscds
    try vogels www.vogels.com you made need an extra fitment plate but they can supply this for you
  5. papercut
    papercut
    Jan 26, 2005
    5
