xilofone
Hello!
Thanks in advance for your help.
Here's my problem:
I have a set of 2.1 Logitech speakers to my TV via DAC (optical audio out to RCA).
Worked fine for about 2 weeks and all of a sudden no audio output.
The speakers are always left on.
Now for the Weird part:
1. when turn the TV on there is no sound. If I unplug, and plug back in, the left RCA cable, that is connected to the subwoofer, the sound comes through.
2. if I change the input on the TV, from optical to TV speakers, there is no sound if I change it back to optical. Again, if I unplug/ plug the left RCA, sound comes back.
3. If I unplug/plug the optical cable sound is gone. Again, if I unplug/ plug the left RCA, sound comes back...
Also, as soon as I unplug the left RCA plug, sound comes through the right speaker and the subwoofer.
No settings were changed on the TV and audio output is set to PCM
My TV: 43UK6200PLA: https://www.lg.com/uk/tvs/lg-43UK6200PLA)
The DAC I got from e-bay, similar to this one: Optical Coaxial Toslink Digital to Analog Audio Converter Adapter RCA R/L Cable | eBay
Thank you for your help
Here's my problem:
-- As an eBay Associate, AVForums earns from qualifying purchases --
