We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
Question (Very) tight budget for amp
Discussion in 'Hi-Fi Stereo Systems & Separates' started by DaveoRob, Apr 17, 2018.
Tags:
  1. DaveoRob
    DaveoRob
    Apr 17, 2018
    2
    4
    Yorkshire
    Hello,
    I've been using a budget Sherwood amp that I bought 25 years ago but due to a house refurbishment and am looking to move it to a bedroom and buy a replacement main amp for the dining room. Money is tight - I could probably stretch to around £100 so am looking on ebay. When I bought my first system a friend had a NAD 3020i and I reckon I could find one in budget on ebay. So my question is, would I be better off trying to get a newer amp, perhaps something from Cambridge audio, or a Rotel ra-01? The speakers are Eltax monitor iii (probably 15 years old) that will be wall mounted and the source will be a spotify subscription through a chromecast audio. Thanks.
  2. Paul7777x
    Paul7777x
    Jul 23, 2016
    3,647
    North east. U.K.
    +1,329
    This will drive your Monitor 3s with gusto and with plenty to spare
    It’s a solid amp with plenty of reserve power, and it’ll handle any reasonable speaker upgrade you might try in the future.
    No remote with it, but you’ll find on one eBay cheaply enough should you want one.
    cambridge audio 550A amplifier | eBay
    If you need to make it on a tighter budget then either of these two will also happily drive the Eltax speakers. No remote, and they haven’t the power or headroom of the 550A but they’re still a great amp and a bargain too.
    Cambridge Audio Topaz AM1 Integrated Amplifier AMP Bluetooth Quality Pro n ad | eBay
    Cambridge Audio Topaz AM5 Integrated Amplifier 5055300405531 | eBay
    Or this one. Slightly older but plenty of grunt and another solid amp.
    Cambridge Audio A500 Amplifier Amp HI-FI separate stereo component | eBay
  3. Paul7777x
    Paul7777x
    Jul 23, 2016
    3,647
    North east. U.K.
    +1,329
    Ps, I bought my then 7 year old nephew a pair of those speakers and a nad amp years ago.
    He loved it. Plenty of fun and volume was had by all. :thumbsup:
    His parents hated me, but he had it for 8 years so I have a soft spot for the Monitor 3s
  4. muljao
    muljao
    Jan 24, 2017
    2,084
    116
    Ireland
    +764
  5. muljao
    muljao
    Jan 24, 2017
    2,084
    116
    Ireland
    +764
    In the classifieds here
    For Sale - Denon PMA-720
    My friend bought one of these on my recommendation and is deighted with it, a good powerful amp 100 quid
  6. Ugg10
    Ugg10
    Apr 17, 2009
    3,450
    +1,737
    On the nad side
    320bee, successor to the 3020 but bee quick (see what I did there!) - NAD C320BEE Stereo Integrated Amplifier in Silver Hi-Fi Unit | eBay
    Review GoodSound! "Equipment" Archives
    Or the non bee version in the classifieds on here fir £60 For Sale - NAD C320 Integrated Amplifier
    Or an Arcam 7 - Arcam Alpha 7 Vintage Built In Phono Stage Stereo Hi-Fi System Amplifier | eBay
    If you are really lucky you may be able to bag an Audiolab 8000a, a few have gone through recently around £100.
  7. DaveoRob
    DaveoRob
    Apr 17, 2018
    2
    4
    Yorkshire
    Thanks for all the help. Much to think about. I like the look of the Cambridge Azur 550. No-one has mentioned the NAD 3020i - that's the nostalgia choice as the amp I really wanted 25 years ago but does it just not make sense against modern rivals?
  8. Paul7777x
    Paul7777x
    Jul 23, 2016
    3,647
    North east. U.K.
    +1,329
    The 550 is a solid, powerful amp. All you’ll need.
    The Nad 2020 is pobably still a decentish amp.
    But at that age, it’s going to be out of spec most likely, bias drift and probably capacitors will need to be looked at.8
  9. Timmy C
    Timmy C
    Oct 10, 2003
    5,716
    +596
    I had one of these many years ago. Pretty sure it was a step or two up from a 3020 but I could be way off the mark saying that. I liked it as far as I remember but I blew a channel (or at least it stopped working on one channel) and I used that as a poor excuse to go out and buy a whole new set up!
    NAD 3240PE Power Envelope Stereo Amplifier MM Phono Stage Hifi Black Separate | eBay
  10. Paul7777x
    Paul7777x
    Jul 23, 2016
    3,647
    North east. U.K.
    +1,329
    I’m pretty sure that’s the one I got for my nephew too.
    But as I said, it was a good number of years ago and they are getting old now. Great amp though.
    Also, if I was spending the £130, I’d go for one of the newer BEEs. All round more modern power supply set up and newer too.
    The one linked to by Ugg10 above looks like a good buy if you’re set on a Nad. As with the 550, plenty of power and headroom.
