Very Strange Problem Scarts On T.v
Discussion in 'Cables & Switches' started by bigjonnyauk, Jul 28, 2004.
  1. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    761
    midlands
    +17
    Hi All
    WONDER IF YOU CAN HELP
    i have a bush t.v ok not brilliant but for the prob i am having shoudnt matter
    t.v has 2 scarts one rgb one normal
    the ntl,dvd player and the video all work in both scarts no problems
    the ps2 however will only work in the rgb scart when i put it in the normal scart i get no picture
    have changed settings on ps2 still no joy
    only think i can think of is the scart i have is a non official one it is a rgb scart with the switching to stop the green dvd screen
    could this not have normal pins on it or something :lease:
  2. WILD9
    WILD9
    Mar 12, 2003
    156
    Cheltenham
    +6
    Id imagine it almost certainly doesnt have the composite pin wired , especially considdering it wont display a signal when connected to a composite scart socket.
  3. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    761
    midlands
    +17
    ok just treid a normal ps2 official lead same problem
    but get this when i take out the scart in the rgb scart picture comes back its like my ntl box which is plugged into the rgb scart is overriding it and disabling the ps2 pic on non rgb scart
  4. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    761
    midlands
    +17
    ok update had my settings on auto switching on ntl box turned this off and nearly there
    when i set to rgb the av2 channel is ghosting big time with the ntl pic when ps2 should be showing but when i switch ntl box to composite the ps2 pic comes up fine on av2 and av1 shows the ntl as it should be
    i think there is a problem with my cheap t.v allowing av1 to interfere with a2 when on rgb as its the same with the dvd player
